Results 1 to 5 of 5
Thread: 4L60E TCC lock up at 3rd in OD
    Nov 2024
    9
    Hello everyone
    I used search and looks like I don't know correct words to ask it right
    I wanna use TCC lock up not only in final gear but into both 3 and 4 -3rd TCC on ,unlocks TCC -shift to 4th and locks again into OD mode without touching lever from 3th to OD
    Can it be done with OEM 1999 black box PCM?
    Dec 2019
    MS
    1,094
    Im pretty sure its hard coded to unlock during a shift. I havent messed with a black box in a long time tho.
    Look into a "0411" "P01" PCM swap.
    Sep 2009
    1,130
    Enable shift lock to keep the converter locked, that being said a stock 4L60E will not like that. Beyond that it should lock the TCC in 3rd stock. My 97 Express L31 with a 4L60E locked the TCC in 3rd and 4th stock and would WOT lock at 75 mph.
    Nov 2024
    9
    Quote Originally Posted by Fast4.7 View Post
    I think it will be very harsh shift for me since I drilled 0.120 4th feed and installed sonnax super servo with blocked 3-4 accumulator
    I mean if I rise 3 to 4 changing gear speed above 3rd TCC lock speed will it lock it in OD or its forbidden into PCM firmware ?
    Quote Originally Posted by RDF1 View Post
    I have P01 and wiring -but too lazy to finish wiring for my setup )
    Wanna try it with black box
    Nov 2024
    9
    Tested it
    If I rise 3-4 speed and lowering 3 TCC Lock speed the tranny locked at 3th in OD
    But TCC lock is very slow -it cant release TC clutch in time and hash bump happens every time nevertheless TCC lock during shift is disabled
    Where can I change TCC lock timing to let it release more early ?
