After some research, it appears they do not ofter this for the 2016 Yukon. I did watch an install video for a ZL1 Camaro and it looked failry simple utilizing the pedal harness but not sure this is the same for the Yukon. The guy used the pedal harnes to supply a plug and play 5 V into the controller and form that it went straight into the fuel pump power wire supplying up to 18 volts. It fixed his issue but not sure it is compatable for mine. Have you personaly had any experince installing one of these in a SUV?
I went to the JMS website and they only offer the pedal commander for my application. $400 is a lot to spend without knowing if it is a sure fire fix to my problem. Still waiting on my Multi-relay refund from Nitrous Express and dont want to have to wait on another refund as well. Any foolproof experince is very welcome. If yo udo sugest something, a link or recommendation to where to go to research would be great. I cannot be the only person that is experiencing this with a SUV. Surely someone else out there has already done this?
