Results 1 to 15 of 15
Thread: 2016 Ram 1500 EcoDiesel Trans tuning
    Nov 2024
    Leoville, SK
    6
    Hi I'm new to tuning and am trying to change the shift scheduling on this ecodiesel. I am trying to move the shift points down but am only getting small differences not even close to where I'm trying for. I know what I have set at now is too low but was just trying to get it to change. I am also getting a really weird shift on the 5-6. I only read the TCM as there is a delete tune in the ECM from someone else and it said it needed to be updated to read and I don't want to mess up that tune. If someone has some tips would be great!
    Aug 2021
    Indianapolis Area
    431
    Quote Originally Posted by SK Diesels View Post
    Are you changing the correct tables?
    How low do you want to go?
    Any modification in the truck?
    DodgeBoy.
    Email / Remote Tune: [email protected]
    YouTube: https://www.youtube.com/@dodgeboy2785
    Nov 2024
    Leoville, SK
    6
    Yes on my data log it gives the shift id and i changed those tables unless theres something different you have to change with the accel factor. Wanted to try shifting at 3500 rpm at wot. only mods are a delete and engine tune and larger wheels.
    Aug 2021
    Indianapolis Area
    431
    ok...
    It might be something else... deeper analyze I would imagine.
    Send me an email in case you need remote support: [email protected]
    DodgeBoy.
    Hey I've heard you need to license both ECM and TCM on the Ecodiesel to be able to make changes on just the TCM. Is that true?
    Senior Tuner LilSick's Avatar
    Jan 2022
    fountain valley
    2,260
    yes
    you have to lic the interface to the vehicle (2)
    and then you can lic the interface to the trans (4)
    Nov 2024
    Leoville, SK
    6
    Ok thanks so to lic the interface to the vehicle is writing the update to the ecm and lic the interface going to mess with the ecm tune I have from someone else?
    Jan 2022
    fountain valley
    2,260
    by vehicle i meant = serial number of pcm of said vehicle
    licensing that serial number to the interface does not require any writing...
    Nov 2024
    Leoville, SK
    6
    ok thanks I'll give that a whirl
    Jan 2023
    7
    Shift Calculator for ZF8
    Here's a shift calculator I made for the ZF8
    Currently setup for a Hemi, but if you verify your gear ratios and set the rpm limits where you want it'll make some nice shift schedules.
    ZF8 - Shift Utility.xlsx
    Quote Originally Posted by LilSick View Post
    yes
    Thanks Lilsick, also have you ever tried to use HPT on a Ecodiesel or any Ecu/Tcu that has been tuned by a PowerGate 2 or 3 handheld device? I have a tune already installed, I got it primarily to have Manual shifting enabled via the + - buttons on the steering wheel, but the shift schedule is horrible and lugs the engine if i don't intervene in certain scenarios. I've been wanting to use HPT to correct some shift points but a little worried to use it on a Ecu/Tcu that has been tuned by another device that it may potentially cause issues or even Brick the TCM and I haven't heard of anyone else doing this before.
    Jan 2022
    fountain valley
    2,260
    no, i have not
    i would be surprised if the licensing with hpt was any different tho
    but although i do not have any experience with that controller, i agree... i too would be leary of flashing it with a second software
    i wouldn't do anything until the PCM read was visable!
    The power gate will fault if you change the tune in hp and then reconnect the power gate . You are supposed to flash back to stock with the PG , change the tune with HPT and then resync the hpt modified Tcu with the PG again
    Quote Originally Posted by GSLSE20B View Post
    Yea I know, The idea was to move away from the PowerGate bc the ppl i bought it from wont do any calibration changes even tho the only change i want is to the shift points bc of how bad it lugs in certain situations. But i also don't want to unmarry the PG Bc this file enables Manual shifting instead of Electronic Range Select. Hpt as it is now will not allow you to enable Autostick unless i would've used HPT from the start.
    Are you Familiar with using the Powergate software and loading files onto the handheld devices? I have a question about getting an old file i have on a PG2 back on my truck, but the company i bought it from can no longer help me with any tuning related services.
    Nov 2024
    Leoville, SK
    6
    Quote Originally Posted by J.Dial View Post
    Hey I used that and it worked great thanks! I wasn't adjusting the downshift tables like I should have been was my problem. So with these ecodiesels at least on this one I only had to license the tcm not the truck so 4 credits only. Thanks guys!
