Hi all! I have a client/work collogue with an LS swapped 62 Chev. I tidied up the VE table on an SD tune from an off the shelf package he'd been given, ran great, no issues. He drove it for about 100 miles and then during the trip al of a sudden it was misfiring and wasn't running so good.
Here's a log of me starting the car up. Perfect smooth idle 650-700ish, after you give it a rev on decel it starts to misfire and is way too rich. Half way through the log you'll see I manually adjust the IAC opening to bring it back but the idle desired airflow and dynamic airflow refuse to line up, even though they were beforehand. I've tried another MAP sensor and IAC valve with no change. I've unplugged the O2's as they were trimming and making it worse.
I'd just appreciate any input as I don't really want to make any changes to the tune seeing that it was running fine for a long time, I just can't figure out what has failed that could cause it run fine at start then misfire after throttle input!
