There is under the part throttle tables, but Full WOT ones. i know HPT has alot of missing tables here and there but I seen so many cant recall (It has tables for Normal A B Hot Engine Hot but the TUTD stuff like part throttle)
Factory Stock 97 SS M6 13.51 @ 104.3 mph
Stock Longblock LS1 w/ 233/238 P.S.I. Cam
10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
'99 TA trunk mounted 76mm 6 Liter
9.0s in '09 @ 153 MPH
Turbo 5.3 Volvo 740 Wagon
32psi and still winding out 5th on the highway somewhere
No, there are no TUTD WOT tables.
There is a switch to select what should be used under WOT - Normal WOT and Hot Trans WOT or regular TUTD and TUTD Hot.
In my 2011 truck calibration it is set to use Normal WOT and Hot Trans WOT.
2011 Cadillac Escalade L94 w/LS3 valves and valve springs
I didnt think so. Access with EFILive or TunerCats or?
How do you access that with user defined parameters?
