Results 1 to 9 of 9
Thread: need help adhd is killin
    i have been playing with hpt for a few years but never have been able to really get a graSP on tuning i can get something running idleing and driving mainly by luck im sure but when it comes to histgrams and all the lingo my adhd kicks in and i cant take in any of the info and retain it lol i have a 05 2500hd with long tubes and a truck noris cam nsr everything else is stock i cant get the fueling right to save my life and feels like its rough idleing and idles high in gear will push the truck 10-15 mph but in park idle shoots way down this is my firsrt time posting on here so i hope im doing this right gay rots drives ok idle hangs high while rolling12-9.hptgarrets truck short drive 12-9.hpl
    Nov 2006
    4,038
    This is a complicated thing to do. I'd say your options are
    1. Read and watch as much info as you can get your hands on.
    2. Post your tune, logs and hope that the community tunes it for you and you get a satisfactory result
    3. Hire a remote tuner. From that point its flash, drive, email, flash, drive, email etc..
    Tuner at PCMofnc.com
    Jan 2015
    Arizona
    940
    there comes a point when we must realize somethings are just out of reach.
    Id look for a local tuner and have them go over your tune.
    did the tune and log not post??
    Aug 2006
    5BA8
    4,942
    Good Lawd I suggest finding a punctuation and caps key so people can read that mess.
    EFI specialist
    email=[email protected]
    Sep 2023
    36
    Someone correct me if I am wrong here, I did not dig deep in your file, but the truck norris cam is not a "big" cam. Your idle airflow in gear is almost double of that of a stock 2500 file I have. I am assuming you had copied some random info you found online, or threw random numbers at it. I have not done that specific cam but I would try lowering that since you are idling high in gear, along with it basically driving itself.
    Install yourself a wideband to read your AFRs if you are struggling to get fueling right.
    As the others said, might be best off to find a local tuner. You will soon be doing more than a cam swap if you are just guessing on your tune file. I too struggle with adhd, it takes me a good minute always re-reading posts and typing my reply out, but a little punctuation and good writing goes a long ways...
    Nov 2006
    4,038
    I'd argue against finding a local tuner and look for a good tuner. There are just so many hacks out there.
    Jan 2015
    Arizona
    940
    yessir, this is sad, but needs to be said.
    I'd never suggest using the very first tooner found, need referrals first
    Feb 2024
    224
    Still using factory fuel injectors and fuel system? Running lean almost completely across the board. If you were attempting to tune the VE Table, the MAF needs to be disabled so it is running in closed loop speed density. ENGINE>DIAG>MAF Frequency Fail High, set to 1hz, MAF and VE are both lower than a stock file i compared it too, but trims are indicating lean? Make sure you are applying the tables in the correct way. Might be wise to also confirm proper fuel pressure before going any further. Also, what's up with the changes made to the Engine Diag>Misfire>Cylinder Mode>Idle(Not Moving) and Idle(Moving Tables)?
