Results 1 to 6 of 6
Thread: P061
    Jan 2015
    573
    P061
    2014 5.7 ram. Owner installed a performance cam but specs unknown. Every time I get the idle close to stable, I get the p061 code and it goes into reduced power. If I back off of my setting some, I get no code but it dies. I need help
    poop2.hpt
    Senior Tuner LilSick's Avatar
    Jan 2022
    fountain valley
    1,610
    i can give it a shot
    do you have the factory read?
    shoot me a email
    [email protected]
    don tanklage
    Jan 2015
    573
    Yeah I do actually, I think I am on the right track now. I found a thread that said to max out the diagnostics for several codes (this one included) that I had not run across yet. Making much better progress now but not exactly what I would have imagined. Check these out.tune so far log.hpl
    stock read.hpt
    Tune so far.hpt
    So this issue now is that the throttle body does not follow the pedal for the first 20% of pedal travel or so. Then when it starts to, it will either die or start surging back and forth. I believe that this is from transitioning from idle adaptive airflow to pedal follower. idle adapt says one thing and pedal follower along with torque requests says another so it is getting confused. I plan today on calibrating the new idle throttle opening requirement to the requested torque and see if I can figure that out.
    Jan 2015
    573
    So it turns out that It was all in the ve table. Once that is close then the rest kinda falls into place. This things is no very smooth to drive though that is for sure. It actually drives bad. Like small jerks and hiccups all the time. My other issue is that it only drives at all without dying if I have the ve table set to what I would have thought was absurdly low. Like 40% of what it was originally.
    What makes it run.hpt
    Jan 2022
    fountain valley
    1,610
    have you installed a wide band?
    are you logging lambda?
    Jan 2015
    573
    No lambda no wideband. Not my vehicle.
