Results 1 to 5 of 5
Thread: (MPVI3) Interface not opened: not found
    Hey everyone, i recently purchased a new MPVI3. Every time I connect it to my laptop, open editor or scanner and go to the Info icon and I get the error as follows:
    12/10/2024 6:38:08 PM
    VCM Suite Product: VCM Editor 5.0.4
    Operating System: Windows 11 (build 22631)
    Microsoft .NET: 4.0.30319.42000, 4.7.1 or later
    CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz
    Available Memory: 2,011 MB
    Interface not opened: Not Found
    It's not recognizing that my interface is plugged in. If I completely uninstall and re-install VCM suite, I can occasionally get it to recognize and provide info.
    With either the editor or scanner open if I try to resync interface it says "Please connect an MPVI device". It seems as though the software or my computer will not recognize that the interface is connected.
    I have tried going to documents>HP Tuners>settings> and deleting license.dat file, but it did not work. Any help will be appreciated.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,713
    I would recommend opening a support ticket.
    You can open a support ticket here https://support.hptuners.com/
    Dec 2024
    1
    Try a different USB cable. My cable would only work as a "charger" out of the box, no communication.
    Tested with multiple other USB cables and had no issues connecting.
    Aug 2023
    9
    I have been pulling my hair out trying to connect my device to car/laptop. It worked fine previously so I was sure the cable wasn't the issue. But I tried another cable for the hell of it with no joy. So reinstalled driver & software still with no luck. Then tried one more cable. Woohoo!! Success!! ��
    Just wanted to say try another cable even if it worked previously. I left the device & cable in my car attached to laptop & it subsequently became bent & damaged hanging from device.
    Good luck. ��
    Feb 2025
    7
    hey so iv been having the same problem and i finally just uninstalled the beta suite then downloaded the net 8 desktop runtime then installed the stable version. I opened vcm editor connected the interface via the cable supplied. it resynced first try.
