Results 1 to 7 of 7
Thread: Sumtingwong
    Jan 2015
    573
    Sumtingwong
    2 Questions. What is causing this saw tooth pattern in my rpms while cruising? You can feel it what ever it is and its driving me nuts.
    Also is the map supposed to read this high?
    WONGTUNE.hpt
    WONG.hpl
    Dec 2019
    MS
    826
    Your ignition timing is going crazy as well. At first i thought it might be a misfire.
    Jan 2015
    573
    Ignition swing at idle is due to a cam swap of some size. its a little choppy.
    Aug 2006
    5BA8
    4,956
    Ignition swing at idle is your adaptive idle control at work.
    Are there any more TCC pids available? It looks like the converter unlocking and locking again.
    EFI specialist
    email=[email protected]
    Senior Tuner LilSick's Avatar
    Jan 2022
    fountain valley
    1,646
    Quote Originally Posted by reubone View Post
    1) What is causing this saw tooth pattern in my rpms while cruising? You can feel it what ever it is and its driving me nuts.
    2) Also is the map supposed to read this high?
    1) trans is either just barely trying to downshift, a clutch pack is trying to slip, or as stated the convertor is unlocking for a split second.
    2014 zf8, you need to do another read of both pcm and the trans
    2) NO - 75 kpa at idle, 100 kpa at cruise is way wong
    [email protected]
    don tanklage
    Jan 2015
    573
    Quote Originally Posted by LilSick View Post
    Ok this is the information I was looking for. Call it bias but I felt it had something to do with the converter possibly. Side note, If i read again, I have to license the trans separately correct?
    Excellent information or confirmation into what i thought might have been wrong...wong. The map calibration data seems to be correct and they swear the map and injectors are stock. I have my doubts.
    Jan 2015
    573
    Looks like we're on the right path...at least I hope so
