Results 1 to 18 of 18
Thread: Speedo Correction after Tire Diameter Change
    Apr 2007
    Myakka FL
    13
    Hello All:
    I just ordered my Pro Tuner (Haven't received it yet) and curious where I should start reading to fix my first issue with my 2004 Silverado 2500HD 4X4 with a 6.0
    I swapped out the stock 245 70 16's for 295 70 16 BFG Mud Terrains and want to have an accurate speedometer and proper shifting.
    I hope this is a good point to start playing with the new toy.
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Here's the best way I have found:
    This was for an F-body so the tire diameter doesn't apply to your vehicle but the math does.
    1st:
    Check your roll-out in inches.
    Mark the tire & the ground (at nomal tire temps after driving).
    Rotate one or two revolutions (divide that value in inches by 2 if you do 2 revs ). Then mark the ground where the tire mark makes it's 1st or 2nd revoltion. It should be ~88.18" If it's different, time to rescale.
    Here's the math on how to do the speedo rescale:
    Tire revolutions/mile = Inches per mile / Tire Circumference Inches
    Tire Revolutions/mi = 63360 / 88.18 --- based on (28.07" tire * Pi)
    Trans revolutions/mile = Tire revolutions/mile * Gear ratio
    Your values:
    (63360" per mile / 88.18" tire circumference) * 4.56 gear = 3276.33
    Take that value and multiply by the Rev-Trans value (40 in *most* cases) to get the VSS Pulses/mile = 131053
    Put your values in the appropriate places and your speedo's dead on. Check with a GPS if you have doubts.
    EC
    Always Support Our Troops!
    Apr 2007
    Myakka FL
    13
    Thanks EC_Tune
    Here's my start and I haven't gotten my Kit yet. I can't wait to figure out how to extract my program from the ECM and look into the code.
    So my '04 Silverado probably produces 40 pulses per Rev.
    I should see a value calculated off the old 245 70 16's in the code based on the 40 pulses and this would confirm the pulse count. Then follow your excellent advice and calculate the new total using you example and enter this data and reflash the EEPROM with the modified program.
    I travel like 300 days a year and this is one of those times I can't wait to get home and play with the new Toy!!!
    H3
    Apr 2003
    Almost 2000 feet.
    7,876
    Done and done!
    Only "extra" tools you need are something to mark the ground (pennies work pretty good!) and a tape measure to get the rollout in inches.
    Mar 2007
    Vancouver, BC
    68
    what about using the tire size feature? click on the unit conversion menu in the editor, enter your tire size in as 295/70r16, you'll see the spot to enter it, now that will give you the tire diameter. Click on speedo in the editor and there is a spot to enter in your new tire size, copy over the existing gear ratio from the greyed out box next to it and enter in your new tire size and click commit. It will change all transmission shift points automatically to correct for your tire size as well as correct the speedo for u
    03 4x4 ECSB Silverado 4.8L, 305/40/r22, remote turbo @ 6psi, 44# injectors, Tr6
    Apr 2007
    Myakka FL
    13
    I'll look at the that and have the software calculate and also perform the calculation as Ec has explained. it will be interesting to see how close the software gets to the real world measurement. I got my delivery date recently and can't stand waiting to get my tuner. I have downloaded much reading material. This is going to be awesome!
    Sit'n in the Hotel Bar checkin out the forum, I love it. Can't wait to get home.
    Apr 2003
    Almost 2000 feet.
    7,876
    Problem is, the calculators don't take into account tire "squish" that is there when you put 1000+ pounds on each tire.
    Mar 2007
    Vancouver, BC
    68
    ahh i gotcha, ya i wonder how much of a difference it would make, would be interesting to figure out. I just got hptuners 2 weeks ago so im still early in the learning process!
    Apr 2003
    Almost 2000 feet.
    7,876
    This ought to give you some idea:
    2003-2006 Hummer H2 uses a BFG 315/70/17 tires (34.5" according to BFG)
    in the stock speedo cal they are 33.69"
    That's almost an inch of tire squish.
    Apr 2007
    Myakka FL
    13
    Hi EC:
    I received my PRO Unit today and couldn't start the software, says invalid activation key. I emailed customer support. Once iget that functioning I'll download my trucks bin file and edit the Tire info. Thanks for the formula and method.
    I came up with 102123.24 pulses. I listed the wrong tire size, they are really 295/75/16's and with the real world measurement at the tire pressure I run it was 101.75 inches per tire revolution (approx 33.3 inches diameter)
    Triple H
    Apr 2007
    Myakka FL
    13
    Hi EC
    Hi EC Your the Man
    I have tried to type three replies and hit the wrong buttons and blown the responses!!!!!
    I used your info from your replies to me and they worked excellent!!!!!!
    Refcer to my responses previously and my Speedo is spot on!!!!
    Apr 2003
    Almost 2000 feet.
    7,876
    Congrats & my thanks to Chris for explaining how all this mess works in the first place.
    Apr 2007
    rutherford nj
    13
    what is the Rev-Trans value? i noticed you said most of the time its 40.
    i am trying to calibrate mine, i figuired out how to do it but not sure on the trans value= 40. is it 40 on a 99 trans am. 3.23 gear.
    thanks
    99 trans am
    p1sc procharger, fmic, alkycontrol, ecs fuel system.
    6.0 heads, ls6 cam, ls6 intake, accufab t.b,slp headers,y-@ cats,borla,
    2000 benz S500
    Apr 2007
    rutherford nj
    13
    nevermind, got it.
    thanks.
    99 trans am
    2000 benz S500
    Mar 2005
    Austin, TX
    63
    On my way to work, the police put a radar box along the side of the road. I found my speedometer was off by 2 mph at 60mph. Finally tweaked the Tire/Gear Ratio until the speedometer matched the radar box. My new ratio is 6.879 (25.66"/3.73) and my old number was 6.70 (was to account for weight on the tires).
    2008 Corvette Coupe
    Atomic Orange, 3LT, NPP, F55, CC3 and MN6
    Dec 2006
    Washington State
    96
    I never thought there would be some thing so simple I would like about edit and Cats over HPT but this is it!
    Ellis
    Speed Secrets
    95 Z28 18* LTx
    95 Z28 LSx converion
    03 CCSB 4x4 D/A
    Apr 2005
    Sugar Land, TX
    1,198
    Quote Originally Posted by Blacker View Post
    Were you reading 58 or 62 mph? Forget which way to go but if I remember right it backwards than what you would envision.
    Advanced Tuner Programmer's Avatar
    Jul 2007
    244
    Quote Originally Posted by TwoFast4Lv View Post
    Absolutely !
    2009 Cadillac CTS-V 196.7 MPH on the Salt
    Superflow SF600 FlowBench -- Superflow Autodyn 30 Chassis Dyno -- Superflow SF901 Engine Dyno--RaceLogic Emulator -- MikiPro Logic Emulator -- ASNU Injector Flow Bench --
