Can someone please help me?
1999 GMC Sierra 1500 2wd
Gen3 5.3L .020 over
Flat top OE style 4.8 pistons with LQ9 rotating assembly\
706 heads, LS9 head gaskets, ARP studs, PAC 1219 springs, pushrods, trunion rockers, etc.
8.1l injectors (42LB)
8.1l fuel pump to match flow of injectors
stock 5.3l fuel pressure regulator
Cam is Tick torqueMAX stage 2
211/217 .535"/.527" LSA 113+3
Operating range idle to 5500rpm
2300stall installed in mild build 4l60e. right now rear gearing is 3.42 AND will be installing 4.10 as soon as I get the time.
I know he has knock disabled and i believe due to the false knock of the header slightly touching the passenger side frame.
I know he has MAF disabled or did until i took it back to him yesterday to fix cold start up. it would start cold but wouldnt "wake up: until it reached 110 degrees, then it would run fine.
When i got back to him yesterday, he said he added something to cold start enrichment and it was fixed..... i got out here this morning to see and its 100X worse and wont even run normal even after 110 degrees. I have an MPVI2 and have pulled both files before and after he changed it... I purchased credits and reloaded the original faulty file just to make it run.
With the original tune, the truck made 305.1hp to the wheels on the dyno.
Attached are both files, the original the tuner initially did and the second is the one he changed yesterday.
original and final are the same tune and the modified is the same.
99_Sierra_original.hpt
cold_start_final.hpl
99_Sierra_modified_1_11_25.hpt
cold_start_modified.hpl
