Gentlemen,
This topic has been exhausted, but I can NOT find a solution. I've read virtually every post on this topic. Several years ago Chris from HP Tuners figured something out , but the solution was not made known.
Have a 1966 Chevelle with LS3 with "fast cam" 495hp, using an E38 ECM out of a 2009 Chevy Express van. Have a 4l80E transmission. Vintage Heat/Air system.
Just some background on how this is currently wired. All is going through the SpearTech wiring harness and Dakota Digital BIM and ECM (computer).
Using 2 separate 40 amp relays. The yellow wires are going to the battery with in-line fuses. The red wire is going to the fans + wire. Fans are grounded to the chassis, Battery grounded to the engine. Engine grounded to the chassis and body/frame. (can't have too many grounds. LOL.)
The orange wires are connected to the ignition to activate the relays with the key ON. The gray wires are the ground signal wires..
We used a trinary switch on the AC/dryer.
The GRAY ground wires from the relays are commonly joined and routed and then split with one branch going to the trinary switch on the AC dryer, and the other side of the trinary circuit is to ground, and the other split gray wire is going to the fan#1 wire of the ECM. Remember the gray wires are common. I wanted to activate BOTH fans, on and off together at full speed.
As for the other circuit of the trinary switch, one side goes to the AC/comp and the other side of that circuit goes to the Vintage/Air compressor wire. This is done so that the compressor will only turn on and off based on pressures and therefore with good airflow does NOT kick on when a highway speeds.
Using the HP Editor the fan setting are DISCRETE and set to turn on at 205 and off at 199. I'm running a 180 stat. Cruising on the highway the ECT reads 197-198 degrees. Therefore my fans would and should be off on the highway.
The fan turn on at 205, but even when I get the ECT down to 195-196 with a fast idle the fan does NOT turn off. If I turn off the engine and re-start the fans are off until 205.
When using the HP Scanner mode I can manually turn the fan on and off.
Somewhere in the form I read about a timer set too high and someone's secondary fan would not turn off until that was addressed. I'm wondering if that could be an issue. Even though I have 2 fans, everything is wired as if running only one fan, but using 2 separate relays.
I am completely at a loss. I'm getting help from members on this forum, but I need more help. PLEASE. Anybody from HP Tuners
