Originally Posted by
bmax0517
I don't know how I missed that, thank you! The values you gave me fixed the low rail pressure. I guess I assumed the table they gave was for a standard CP3 since they provide a kit with a regular pump and one with a 10mm pump. But seeing how high the numbers in there table are, I guess it was probably for the high power pump after all.
If I wanted to fine tune the surging a little bit beyond that, are there any other tables I should look into altering? Or would it just be slight changes flow vs. current table? I assume this would be by building a similar table in the scan tool and logging all the actual current values over time
