Results 1 to 16 of 16
Thread: 02 gmc issues.
    Jan 2025
    9
    02 gmc issues.
    02 Gmc 6.0l
    stock heads, truck norris cam, 36lb AUS injectors, and lq9 flattop pistons.
    Finally got it to idle decent but on the struggle bus figuring out where i am going wrong at new to fuel injection, always been a carburetor guy. trying to learn something new. any help would be greatly apricated take 45.hpl yup its still fucked up.hpt
    Dec 2019
    MS
    1,091
    Are those ebay AUS injectors?
    Nov 2006
    North Carolina
    4,648
    Are you using a wideband? You have it forced open loop. This cam will work fine in closed loop. Might give you some wiggle room. Keep hammering away at the VE table while the MAF is failed to make sure it is solid.
    Your BRAF is way to high. I'll bet this is coming from a throttle body that needs adjusting. You'll need to log iac counts, tps voltage and LTIT and STIT to get this correct. I made a guide years ago to help physically set up the throttle body for the new mods.
    https://www.pcmofnc.com/2021/03/05/i...throttle-body/
    Jan 2025
    9
    Quote Originally Posted by RDF1 View Post
    amazon but i think they are the same. only 36lb injectors i could find in a hurry needed the truck drivable... my car broke needed a vehicle AUSInjection_56010-320_GMdata_HPTuners (1).xls they have pretty good data sets for them not sure if i entered it all correctly
    Jan 2025
    9
    i do not have a wideband on it currently. trying to get to run decent enough to drive back and forth to work then steal the wideband off my car this weekend to get it fine tuned.
    throttle would make sense way its shutting off going from drive to reverse.
    Dec 2019
    MS
    1,091
    Ok. Looks like you got the data in there right.
    Jan 2025
    9
    roadtest450.hplgetting closer but still fucked up.hpt
    think im getting closer
    Nov 2006
    North Carolina
    4,648
    Just keep working at it. If you have any specific questions I'll be glad to try to answer.
    You should try logging STIT and LTIT to get the BRAF in order.. VE should be ironed out completely first but you can start working on that.
    Jan 2025
    9
    Would you by chance have a good layout for this?
    Nov 2006
    North Carolina
    4,648
    layout?
    I've tuned a ton of them. I could likely get it 98% on the first try.. Is that what your asking?
    Jan 2025
    9
    for logging the two in the vcm scanner was trying to figure out how to log them the best way to be the most helpful to work.hpl
    Jan 2025
    9
    latest atempt.hptroad test.hpl
    Am i chasing the right rabbit?
    Nov 2006
    North Carolina
    4,648
    Seems like you are making progress.
    Jan 2015
    Arizona
    1,161
    and thank you for it, very helpful
    Jan 2025
    9
    Got a new random issue every once in a while it will crank and pop out the exhaust but not start then after a couple trie's it will fire up and run fine. every time i've tried to catch it with the scanner it starts fine.latest atempt 4.hpttrail and error.hpl
    Oct 2004
    616
    That is usually a cam position sensor issue. I would make sure there are no loose or damaged wires going to it.
