Results 1 to 2 of 2
Thread: 2003 Duramax need stock file
    Sep 2023
    Texas, DFW
    7
    Post 2003 Duramax need stock file
    Hey guys,
    I am currently doing a duramax swap into my 05 Hummer h2 and I have a 03 silverado 2500hd for a donor truck. The truck is a 2wd and I am using the 4x4 transmission from a 02 gmc duramax which is a completely run by a completely different pinout on the ecu and fuse box etc... so that forces me to use the pcm and transmission control module from the 03 truck.. So basically I'm needing a stock file from a LB7 that is 4x4 that is like a 03-05...
    Thanks!
    Blake Rodriguez
    2000 FRC Corvette
    -BTR Stage 3 kit, LS3 Injectors, Cat Delete, X-pipe
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    490
    Do you have a read out of the ecm and TCM that you have now?
