Results 1 to 11 of 11
Thread: E40 07 Colorado swap Segment OS needed
    Mar 2021
    Clarksville, TN
    46
    I have a 07 Colorado with a 05 5.3l swap. with 08 Yukon intake and throttle body E40, t42 and harness out of a 06 GTO. Got it all running but pedal won't work. Pedal is from 06 Trailblazer 4.3l. Current performance web states that I will need to segment swap to a Trailblazer with a 5.3l to get pedal to work properly. I have been searching everywhere to get the correct OS for a segment swap. I have found a match for the ECM but not the TCM. I even tried to remove the TCM controller and with the same OS the segment swap is still greyed out. I also ordered a Trailblazer TCM hoping to find a matching TCM OS with no luck. Also downloaded dozens of tunes from the Repository.
    Have been using HPT for about 3 years with several swaps and tunes under my belt but never messed with the E40. Is this some issue with this ECM in general. E40's are running over $350 on Ebay so I don't want to order a bunch to try to find a correct one.
    ECM 12603159
    Trailblazer TCM 24239036
    GTO TCM 12590424
    I have double and triple checked all wiring from pedal to TB.
    Tuning Addict
    10,887
    The segments you need to swap to make it work with a different pedal are the two segments you cannot read or write in HP Tuners. GTO and the trucks never shared the same OS, but they do use the same ECM service number.
    Also, if you just change the whole OS from GTO to Trailblazer, you can't do that with HPT either. Because, same problem, writing a Trailblazer file to it won't change the two GTO ETC segments. To change the OS it has to be done with GM SPS & Tech2/MDI/other J2534 device.
    Gen 4 stuff like this should go in the Gen 4 section, one door down from here.
    Tuning Addict
    10,887
    Hang on - is the pedal connector pinned out according to the GTO diagrams, or Trailblazer? Because they are different.
    Tuning Addict
    10,887
    Mar 2021
    Clarksville, TN
    46
    it is a 24x gen 3 setup though
    Mar 2021
    Clarksville, TN
    46
    i matched the GTO pinout and probed each with multimeter for continuity and also for the proper 5v reference and low reference
    Mar 2021
    Clarksville, TN
    46
    I was worried about this so i just ordered a E40 from a 5.3l trailblazer hopefully it will work. then i can hold this GTO ecu and TCM and sell later if I don't use it. thanks for the info
    Tuning Addict
    10,887
    Quote Originally Posted by techmann52 View Post
    In HPTuners-world E40 is a Gen 4, look at the 'Tune Details' tab in your editor.
    Can't use the GTO pinout at the APP connector, it is different. A/B/C does not correlate with 1/2/3/. The pin numbers at the ECM are the same, use the Trailblazer diagram.
    Mar 2021
    Clarksville, TN
    46
    I went with how they corelate by the diagram, and wired the TB pedal to match, thinking its a resistance difference Between what the ECU wants to see and what the pedal may be putting out. I just ordered a trailblazer 5.3l e40 and will rewire to match when I get it. thanks for your help.
    Tuning Addict
    10,887
    It doesn't work by resistance. And APP1 has to go to the APP1 pins at ECM, and APP2 to APP2 pins, because they return different voltages, for error checking. They even go different directions as the pedal goes down - one goes up with more pedal, other goes down. This is so it can be sure the two signals aren't simply shorted together and only one sensor is working. (on different years/platforms, they go the same direction but different starting/ending points)
    Accelerator Pedal Position (APP) Sensor
    The accelerator pedal contains 2 individual accelerator pedal position (APP) sensors within the assembly. The APP sensors 1 and 2 are potentiometer type sensors each with 3 circuits:
    • A 5-volt reference circuit
    • A low reference circuit
    • A signal circuit
    The APP sensors are used to determine the pedal angle. The engine control module (ECM) provides each APP sensor a 5-volt reference circuit and a low reference circuit. The APP sensors provide the ECM with signal voltage proportional to the pedal movement. The APP sensor 1 signal voltage at rest position is less than 1 volt and increases as the pedal is actuated. The APP sensor 2 signal voltage at rest position above 4 volts and decreases as the pedal is actuated.
    Mar 2021
    Clarksville, TN
    46
    Just to close this thread out. I ordered an E40 out of a 06 Trailblazer with a 5.3l engine (PN 12596679) and the pedal worked. The pinouts for the GTO and Trailblazer were identical for the needed wiring. But looking at the diagram, it appears that the GTO pedal has an extra resistor in it that must have been why it wasn't working like I had wanted.
    Thanks Blindsquirrel for sharing your knowledge
