Results 1 to 7 of 7
Thread: Help on LB7 GM Duramax 2003
    Jul 2024
    19
    Hello we need any help on stage 2 tuning
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    911
    Little bump
    Here is a Tune with very basic fuel added to the petal map.
    Do you have an EGT gauge?
    If not I would be very cautious of running any tune.
    2011 Camaro 2SS Convertible L99 Bone Stock for now
    2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
    Jul 2024
    19
    i will connect the EGT gauge ..but these file is already tuned for stage 2 ? can you double check if you can remove delay on the throttle pedal
    Jul 2024
    19
    Hello
    we have test the tune
    we have to increase the power more (we still have to add more boost still no smock)
    we have shock between moving from 1st gear ratio to 2secound the speed the speed will be between 30-40 the moving is nor smooth there is shock
    Jun 2015
    Aubrey TX
    911
    I can help you do this yourself.
    I do not have a file that I can send that gives you exactly what you want. I only tune my own stuff.
    For what you want you probably need to find someone with a dyno and lots more racing experience than I have.
    Like I said I can help you through the process but I'm not a pro tuner
    Jun 2015
    Aubrey TX
    911
    Second
    See if this gets you heading where you want to be (assuming you haven't found something else
    Jun 2015
    Aubrey TX
    911
    Scanner
    Possibly get some logs to post up
