Hey all, need advice on a few things I'm trying to make sure I understand. Working with a L83+Whipple+stage 1btr cam and spray times are over 6ms above 5krpm, other than that that's the only concern I've seen, no knocking or lean issues.
First with the fuel lobe, is it accurate that I should multiply the fuel Volume axis by 1.14 in leading edge angle because of the cam 14% lobe? If so what does it effect? Pros and cons?
Second, should I change the rail pressure base table up an additional four to five megapascals? Pros/cons?
