Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Still having nuisance start up.
    Jun 2022
    Canada
    101
    Technically starts fine every time then gets a surge. However only if there is a bit of heat in the motor. Dead cold no problem, warm no problem. somewhere in the middle, surge but only for about 20 seconds after it fires up.
    Any suggestions would be great!
    feb4 luke warm surge.hpl
    Jan 29 surge tune.hpt
    Banned
    Jan 2022
    fountain valley
    2,379
    try this
    Jun 2022
    Canada
    101
    Tried it today, still does it all thought the amplitude of the surge is different.... Also at the end of the log I get I big stumble with a bit of throttle input. It doesn't do that all the time but often enough. typically only does it after start up in the first minute maybe. If it wait long enough it doesn't do it and doesn't do it when its warm....
    surge fix attemp.hpl
    Banned
    Jan 2022
    fountain valley
    2,379
    why is the pressure ratio so high at idle?
    is your cam timing is off or is there a significant intake leak?
    your timing being retarded past TDC until 40 degrees C prolly is not helping the idle issue either
    Advanced Tuner Spray-Cam Hell-Ram's Avatar
    Aug 2021
    Yorktown VA
    255
    Your pressure ratio at idle looks just fine to me. However, I do agree with Lil Sick about your startup timing. But I think your issue might be due to the lack of a range of idle timing. Part way through your log, the range in which your timing can swing improves and the surging starts to fade it seems. Not totally sure if this is issue you are referring to. But if so, you can give this a go and see if anything improves. Im just going off of what I was seeing in the log anyway.
    "1MEAN16" Silver/Black 2016 Ram CCSB (4592lbs) NA 398ci Stroker
    +6cc Mahle Dome Pistons w/ 13.1/1 Compression on E85
    Forged 4.08" Stroke Crank, 224cc AFR Heads w/ Titanium 2.165"/1.65" Valves
    Custom Cam 220/238 .611/.589 108.5 LSA 108.5 ICL, 105mm Hellcat TB
    Ported Hi-Ram Intake, NXpress Hi-Ram NO2 Plate kit w/125 Shot(4 sec)
    Tx Spd 2" Long Tubes, ATI SD 15%UD, Ram TRX K&N CAI
    Dual 450 Pumps, Deatschwerks 1000cc Inj, Fuel Cell in Bed
    Built 8HP70 w/ 3800 stall/Detroit Tru-Trac/410 Gears
    Jun 2022
    Canada
    101
    Quote Originally Posted by LilSick View Post
    No leaks as far as I can tell, the cam was degreed when installed 2 years ago.... Ive always seemed to fight it between winter and summer with the substantially colder air vs our summer...
    Jun 2022
    Canada
    101
    Quote Originally Posted by Spray-Cam Hell-Ram View Post
    Thanks appreciate it, Ill give this a shot after I dig out of the snow we got last night.
    Banned
    Jan 2022
    fountain valley
    2,379
    Quote Originally Posted by StupidJeep View Post
    where is the ex centerline?
    has it always idled around .65 pr?
    how much overlap?
    Jun 2022
    Canada
    101
    how much overlap?
    Once it's warm it typically idles around .6 in gear and .5 in neutral.
    As far as the rest of the info I'd have to go digging for the sheet we had everything written down on. Which is buried in a box with the old cam and lifters a couple hours a away....
    Jun 2022
    Canada
    101
    Tried your changes....still does it...
    Aug 2021
    Yorktown VA
    255
    Yea. I misunderstood what your actual problem was initially. I think I may see a couple tune inputs that might cause this issue. But first question I have for you is what fuel injectors are those that you are running?
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    543
    how much overlap?
    Cam is Comp HRT stage 2 .596/.582 220/230 @ .050 113 LSA , Should be installed at 109/110 ICL for best results.
    .50 to .70 P-ratio is the Norm for this cam at idle the Larger Bore/Stroke builds can idle around .45 depending on Compression ratio.
    with 3k+ convertor we don't have this issue at all.
    04 RAMGTX........ 8.82@154mph 392Ci G3Hemi 3250lbs 2.6HP/Ci Naturally Aspirated
    05 RAMGTxtreme 9:45@142mph 426Ci G3Hemi 4000lbs 2.2HP/Ci Naturally Aspirated
    05 Rumble Bee 13.29@101mph STOCK 5.7l , Just a tune, still runs OEM airbox
    09 Challenger Drag Pak 8.65@160mph 426Ci G3hemi 3650lbs 2.4HP/Ci Naturally Aspirated
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
    Banned
    Jan 2022
    fountain valley
    2,379
    a cam with only 220 deg at 050 on the intake lobe...
    that still has a relatively wide lobe separation angle...
    and is installed 4 deg adv...
    (113-109=+4)
    if everything is right (and sealed up) should make more vacuum than that.
    the 5.7 has a pretty nice bore to stroke ratio
    3.917/3.578=1.095
    four stroke engines seem happiest at 1.1 (or better)
    the 5.7 is very close
    the 392 is slightly better at 1.099
    actual overlap depends on how weak the rate is but that is not a lot of camshaft
    Jun 2022
    Canada
    101
    Still just stock injectors. I have more recent log I'll post it up when I get back the laptop.
    Jun 2022
    Canada
    101
    I'm just baffled at why it only does this surging at what seems like a certain engine coolant temp. As when it sits long enough it doesn't do it or if if it's a real short period of time it doesn't do it.... And general only for about the first 20 seconds of run time.
    Jun 2022
    Canada
    101
    Current tune and a log of the surge again.
    surge feb 14.hpl
    current tune Feb 16 surge.hpt
    Aug 2017
    Quakertown PA
    543
    (113-109=+4)
    Hate to break it to you but that is the Norm for this camshaft in a 5.7
    G3 Hemi Videos
    Aug 2017
    Quakertown PA
    543
    This cam is -1* overlap IN valve and Ex valve are closed during Overlap 1* , at 109 ICL the Intake opens while the piston is in TDC dwell ,Exhaust valve is already closed it closed 1* before INVO , NO scavenging to add vacuum. the INV opens while there is still minute residual pressure in the Chamber, at ICL of 117 , this cam will make OEM type vacuum.
    G3 Hemi Videos
    Banned
    Jan 2022
    fountain valley
    2,379
    Quote Originally Posted by PurpleRam View Post
    maybe in your engine, but not in any engine i have ever worked on...
    Banned
    Jan 2022
    fountain valley
    2,379
    which is it
    it cannot be both : )
