Originally Posted by
will_974
From what i can gather, it looks like the vehicle is going into a Sensor failsafe mode
This happened to me at one point. Basicaly it sees a bad sensor state and then modulates the throttle to prevent the engine from hitting boost.
The first thing that jumps out at me in the log is the SCIAP never moves from 99kpa, which needs to be addressed.
Is it wired correctly? In the calibration I see the values are set correctly for the SCIAP sensor, so I assume thats not the issue.
I would first double check wiring, maybe log sciap voltage, which should correctly coorespond with inlet pressure.
Then I would suggest re-enabling AAP sensor tests 1 and 2, ensuring they both pass.
The issue that is happening is being masked by DTC's being disabled in this way.
Also, I do not recommend setting he Supercharger fitted switch on Silverados. They are missing an air temp sensor.
