Needing some help first time tuning on a cammed 5.3.
This is the run down on what I know about the car. It came to me as a fresh rebuilt 5.3 with a Howard's cam. I do not know the specs on the cam. It has a Velocity intake manifold with 92MM cable throttle body on it. The car is a 69 Chevelle with a 3.08 rear gear and 4l60 trans.
The car runs ok at startup and at temp. But stumbles sometimes at stop signs and red lights.
I changed and remapped the MAF to a 5 wire with the internal IAT sensor,after adding a different intake tube and filter.
Changed MAP sensor to a Bosch style to fit the Velocity intake.
Verified the lbs/hour on the injectors.
Used wide band O2 to map the VE tables.
I added timing but seems like it does not like it.
any thoughts on what i could do to help it perform better
Here is the log and tune
Thanks for any help.
