2005 Gto Torid Red
408 Stroker 10.3 Cr
Howard Cam
0.625 Int & Exh, 236 Int 254 Exh 118 Sep
823 Squire port heads built but not ported
Snakeaters 80-lb injectors
Magnuson 2.3 Od cog pulleys 2.7 Front pulley
Innovative West 10% Od 8-rib conversion
Engine cuts out as Ve table hands over to boost Ve table seems to cut out as boost rises to 3.5-psi i have tried everything i can think of so i hope someone can help with this problem, the maf table is tuned and works fine threw the full boost curve but i am exceeding the max limits of the maf sensor thats why i need dynamic Ve working properly so i can move to SD only
