Results 1 to 9 of 9
Thread: Cummins fuel cut rev limiter
    I wanted to do a small write up on fast cut and slow cut rev limiters because I couldn't find much on it myself when trying to figure it out. The Cummins is an inline 6 so it's only appropriate to have a rev limiter that sounds like a ricer. You can achieve this by setting the injector off limit to your desired rmp and the resume rmp closer to that amount for a faster limiter and farther for a slower limiter. My injectors turn off at 2900 and resume at 2890 so it makes that fun wahhh papapapapapa sound. I'm not sure of the effects on the engine this has. I'm below the stock limiter and all it's doing is cutting fuel so I think it's ok. I just wanted to help anyone looking for that same limiter and sound.
    Sep 2023
    415
    You are joking, right?
    Feb 2025
    Assuming for a slower cut, youd just space the "back on' rpm lower for the wahhhhhh puh....puh...puh
    Sep 2022
    12
    I would just like to verify what table is being used for fuel cut rpm. The table used is the high speed govenor table under diesel fueling correct?
    05 Dodge 3500 DRW Flatbed 9500lb empty, nv5600, 4:10 gears, 25% over Bosch Injectors, Fass Lift pump and draw straw, S&B intake, 4" exhaust with 5" dual stacks, 255/80r17 Cooper StMaxx, Self Tuned.
    You don't like to party?��
    Yep, the more space between the cut and add back the slower the limiter.
    It's not a table. I'm not looking at my laptop right now but it is the injector cut rmp and injector resume rmp values. If I remember correctly they are with the all speed governor.
    Sep 2023
    415
    It’s a diesel, not a jap rice burner
    That was just a joke. I know some of the tuners like fire punk I think have these limiters. It's pretty common in the diesel community now. I don't think there's any benefits besides it sounds pretty killer when your spinning tires.
