Hello, and thank you in advance for your input.
I have a ls1 in a 2001 Silverado.
I recently installed a th400 with a gear vendors overdrive.
Added a vss from Dakota digital at the cable speedometer output.
I understand that it is s hard on the overdrive unit to be engaged when in reverse or at low speeds.
I plan on manually triggering the overdrive with a button.
My question is how to go about finding a speed sensitive circuit that I could use to trigger a relay, allowing power to the manual switch.
For clarity, I’d like to make it impossible to turn the overdrive on when in reverse or at low speeds.
Edit- I believe the truck has a 411 pcm installed, if that is relevant information.
Again, thank you in advance.
