Results 1 to 5 of 5
Thread: User Defined Paramters not working in latest Beta
    I purchased User Defined Parameters today. I re-synced the interface and it shows in the info that I have that added. I bought this to use on my E90 file that can only be opened with the Beta version of the editor. I get this when opening.
    UDP works fine in the stable version of the editor (5.0.4) with other tunes I have, but I can't open my E90 tune with the stable version. I updated to the latest version (5.1.3919 beta) and I still get the error.
    I have also noticed in the latest Beta versions we've lost a lot of definitions for the P codes. These used to be there, they are for Supercharger Inlet Pressure Sensors.
    I was trying to do this with the MPVI just hooked to my laptop. Once I plugged into the trucks OBD port, I was able to open user defined parameters. So, I guess if you are using Beta, you have to plug into the vehicle once after syncing for the license to fully take effect. Apparently not so with the stable version.
    Senior Tuner 04silverado6.0's Avatar
    Sep 2021
    Kentucky
    1,599
    I noticed the issue with the dtcs. Not a concern for me but will be for many.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,636
    ​For the user defined params license to show You may need to close out of the software & reopen, then resync & check again.
    If that does not work, please try restarting your PC.
    You can open a support ticket here https://support.hptuners.com/
    Aug 2023
    Nevada
    44
    I've done this. Still no joy. Edit:resolved
