Originally Posted by
gearlash
Connectors are seated and screw is tight.
Lot's of rpm's at a very low speed so we do believe it's low.
20 on the connector rings to the wire on the output speed sensor. The other wire is ground (low ref).
I now have fluid temp. Did not previously due to the fact that we only need to move the car a few ft to determine no out put speed signal.
By manifold switch readings's, do you mean solonoid states on/offf?
The pink wire at the trans connector has 12v and will light an 1157 bulb.
