86.47kpa here and a DA of 9000 in the summerOriginally Posted by EC_Tune
EC, is this what you'd use if you were using this sensor? Seems that going by GM's #s can't really be all too bad, 'eh?Originally Posted by EC_Tune
Formerly known as RWTD
Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
I think that is correct.
Always Support Our Troops!
FYI
I had a small calculation errorwhen I had it as 208/8. The linear should be how many kPa there are within 5V, not at 5V. Since 0V is 8 kPa and 5V is 208 kPa that is 200 (208-8). So it should be as Doug said, 200/8. I did have to edit my offest by adding .33 to it in order for it to match my baro sensor so I ended up with 200/8.33.
Bill Winters
Out of the LSx tuning game
Um, what baro sensorOriginally Posted by 5_Liter_Eater
Whatever baro sensor is feeding data to the baro sensor PID.
Bill Winters
That "sensor" Would be the map sensor .Originally Posted by 5_Liter_Eater
If so then why do changes to the MAP linear and offset not seem to affect the baro reading?
Bill Winters
say what???? i just got 12615136 which is the replacement for 12580698.
i guess im gonna check what it is with the stock 1 bar sensor, swap in this one. put in the new offset and linear settings and check it with key on, engine off.
-carl
Talk about back from the dead...lol
2003 Z06
Forged 347
PTE Billet 67/65 Turbos
FMIC / Dual 50mm Tial BOV's
ID 1000 Injectors
RSI Stage 4 Fuel System
07 Z06 Cam
Tripple Nozzle Meth
ACT Twin disk clutch
25# Boost
edit:
lol, i answered myself! haha
200 and 8.33 worked great
Not for me. It works great when your checking for o psi, 100 kpa. Cobalt baro sensor in my ls2 doesn't read accurately. Its off by %20 at its limits. That's with linear set at 200 offset 8. It gets close to right with linear set at 170 and offset 18. But of course it'll max out at 1.7 bar. Anyone else have this issue?
Check your sensor at 20", should be 33 kpa, and 10 psi boost, should be 166 kpa. Let me know what you get.
look at the spec sheet it shows that the sensor is more accurate from 40 to 160 and goes south outside of these limits real fast. Also when you add the temp adjust outside of 10-85 it goes out also.
Combined, if you have high charge temps and go beyond 160kPa then you will have an increased error.
Use the calibration data sheet to set your slope and offset and tune more conservative at the limits or get a better map sensor.
-Adam Chant SCdyne Performance "Tune it or lose it!"
Got a part # for a better MAP sensor that fits?
