Originally Posted by
HeadstrongMS
I am not saying your way is wrong. I am saying that is alot more complicated, the problem with the wb and the hp tuners is the hp tuners has therr settings on the lm1 to god knows what if the LM-1 has there 0-5v at 5-25 afr and the HP tuneres is reading 10-20 at 0-5 the settings will be off. So all that has to be done is the 2 need to have the same values and they will be damn close with my way of doin it. I said the HP Tuners should be set to 10 --- .5 now the hp tuners is set up 10afr = 0v and 20afr = 5v. with the lm1 programer it dosnt like using a 0-5 volt sweep which it does anyway if you put your values in as 0v = 10 afr and 4v = 18afr that means 5v = 20 afr. you can do 0v = 10, .5= 11, 1=12, 1.5=13, 2=14, 2.5=15, 3=16, 3.5=17, 4=18, 4.5=19, 5=20. It dosnt matter as long as the 2 has the same values.
