Originally Posted by
Jeffgiroc
So I have had no success in getting my changes to the primary VE table to actually take affect and change the AFR readings I'm getting on my wideband. Every time I copy and paste the AFR error values to the VE table the AFR readings never change when i do a run with the scanner. I'm pretty sure i have set up the speed density tune file correctly but no matter what i do to the ve table I can't get the AFR to lean out. I've tried every little thing I can find in the forums but nothing seems to work. I'm using a tune file i got from the people who installed the instigator cam in the 5.7 ls1 that I put in my 86 IROC. I've made a couple of changes to the idle airflow and to the injector minimum pulse width, and it up for speed density. Otherwise it's what I got from the shop. I'm new to all of this so any advice would be greatly appreciated.
