Originally Posted by
tonybalogna
Hi group,
I am new to tuning. I recently had to make changes to my DTC due to having a larger turbo in order to turn off my MIL for smog. I changed P0234, P0243, P0245 and P246 to no error report. My MIL has turned off since the flash. I have not made any changes to my stock tune other than those and I noticed an increase in performance. I suspect is is due to P0234 (Overboost condition), which was an error I got frequently after adding the larger turbo. My question is, what dangers do I run into with these changes. I have not tested the changes on the freeway but I wanted to ask the community for advice to see if I risk any dangers with these changes. Any response will be appreciated.
I have stock injectors, CAI, and HP ignition coil, with a stage 2 turbo 55mm.
