Results 1 to 4 of 4
Thread: 8192rpm is the absolute limit?
    Jun 2006
    Manchester, NJ
    59
    so in my constant battle of deciding to go n.a or boost, I've noticed that HPT fuel cutoff for the L61 ecotec has 8192rpm as the max
    why is this? spark ramp out max rpm is 65,535rpm
    if I do end up staying all motor, I'm going to need around 10,000rpm just to be sure i'll be able to make decent power and utilizing the high revs required of a 4 cylinder n/a car
    is it some kind of ecu limitaion, or can HPT be updated to raise it higher?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    its the pcm hardcoded limit...GM decides how much room in the pcm they'll need for each parameter for each calibration...to move these limits up is not an easy task so yes thats pretty much what your limited to.
    Advanced Tuner gman4dx266's Avatar
    Jun 2006
    Cape Coral, FL
    860
    I have to lmao at your signature editing.
    Jun 2006
    Manchester, NJ
    59
    alright i was just wondering. as long as the ecu will continue to drive the spark as high as I want to go, I can get the fueling done another way
    thanks foff now I can spend my time looking for a solution
