Results 1 to 15 of 15
Thread: Checksum error 4000 during read
    Apr 2007
    8
    I've got a 2002 5.3 harness and computer that I am reworking. I'm bench checking everything and with this unit I keep getting this same error while trying to read it. It fails at 3% everytime.
    "VCM read failed at loc: 4000 error: checksum"
    I've tested my bench setup on my personal harness and computer and I can read it evertime. The problem computer is from a wrecking yard, out of a 2002 suburban, don't think anyone has done any programming on it.
    Any ideas? Thanks in advance.
    Sep 2002
    Chicago, IL
    6,395
    It may have been programmed by a handheld. We've seen that error before when they are programmed by handhelds.
    We got this guy Not Sure, ...
    Apr 2007
    8
    Recommendations? Have it flashed by a TECH2?
    Sep 2002
    Chicago, IL
    6,395
    Yea, that should fix it.
    Apr 2007
    8
    Thanks Keith. Is it possible to do the same thing with a bin file from this site and have it flash entire? I realize it would cost credits to do this.
    Sep 2002
    Chicago, IL
    6,395
    That should fix it as well.. however, I cannot gaurantee that.
    I fixed a few of these years ago in person (due to handhelds) and I recall flashing them entire with a known good file..
    I tell you what.. Take a VCM Suite info log of the vehicle now, post it here (remove your serial # and key).. and try a write entire with a known good file. You will have to license that file (unless you already have a license for it) and the ECM (which you currently cannot read)... If it still throws the error (which it shouldn't), I'll throw you two free credits..
    Apr 2007
    8
    I tried uploading it to here but I'm not having any luck. I put it on my site and you can see it here.
    Suite Info Link
    Apr 2007
    8
    This fixed it. Thanks for the help Keith.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    so just doing the write entire worked fine? Did it use 2 or 4 credits?
    Apr 2007
    8
    Correct entire write fixed it, took 4 credits.
    Tuner Pur_SSyn's Avatar
    May 2007
    Kitchener, Ontario
    73
    I'm receiving the same error on a car I have previously scanned.
    It has not been programmed since, however we suspect the computer may
    be damaged from an arc weld in which 600 Volts was applied to the frame.
    The car also has a weak battery and is now charging for the night. This
    may also be an issue as sometimes the "Preparing VCM" would also fail.
    My concern and question is:
    If the computer is damaged, would I be able to read some of the parameters
    as shown in the screen shot?
    2013 GTM Gen.1
    Modified LQ9 w/G96.00
    Apr 2003
    Almost 2000 feet.
    7,876
    If the battery was low that will throw bootloader errors and other timeouts. The battery has to be at a minimum voltage (reported in the status bar when you read or write) to work successfully.
    Always Support Our Troops!
    May 2007
    Kitchener, Ontario
    73
    Good to know and fits one of the symptoms.
    Thanks and I'll let you know what I find tonight!
    2013 GTM Gen.1
    May 2007
    Kitchener, Ontario
    73
    No go with the new battery.
    The VCM Scanner read 12.4 VDC while reading the Entire VCM.
    I'm still getting the Checksum Error 4000
    This car was previously scanned by me and I have the file on my laptop.
    It was not programmed by another device since downloading the file.
    The car did not leave my side, and I can only conclude that the arc welder
    smoked the computer and/or some vehicle sensors.
    I'm going to try uploading the tune in hopes that any bad cells will get overwritten.
    Failing that, I'll have to start troubleshooting the electrical.
    If anyone could help out with any of the polled sensors that the
    computer requires to start the car, I would really appreciate it.
    I'm thinking it's possible that a sensor was damaged and the computer
    requires a response from certain sensors in order to start the motor.
    If Checksum Error 4000 points to a range of cells, or sensors that I
    should be testing, please list them.
    Thank you in advance...like never before!
    2013 GTM Gen.1
    Apr 2003
    Almost 2000 feet.
    7,876
    If you have the original file, try a Write Entire. There is risk involved but it may resurrect your PCM.
