Results 1 to 15 of 15
Thread: Looks like we have more Throttle body tables to adjust for larger throttle bodies
    May 2006
    Waterbury CT.
    306
    I have long been messing the Throttle area on the GenV E92s with no notable changes.
    When adding larger Throttle bodies the ECM will just pull timing to compensate for the added Area instead of closing the blade.
    I updated my Beta today and see some new tables So Thank you Hptuners.
    I will be testing these out to see how they work wondering if anyone else has used them to adjust for large Throttle bodies?
    I hope that the ECM will recognize the actual Throttle Area, close the blade and maintain the Idle timing.
    Yes I am well aware of tuning VVE and Hacking Torque Tables for a result, Not something I am on board with.
    If the ECM knows the Throttle Area, the TQ Hacking goes away.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,877
    You're welcome.
    The original area value that was visible is not used for much.
    http://www.dsxtuning.com
    Just say no to bull s***.
    May 2006
    Waterbury CT.
    306
    You're welcome.
    Well Thank you Dave Steck.
    I had a feeling you were involved.
    If we can get it added to the 19 ZR1 that would be great for reference, we install 95mm TB on so many cars.
    Had a great discussion with Greg Banish today, Thanks Greg!
    I tested a single change today on my personal car and right away I could tell I had more chop from the cam due to less Idle air and more timing.
    Love this stuff.
    Now to find a way to model the Throttle percent to flow percent of total area for aftermarket TB, Talked with Nick Williams today as well.
    Ted.
    Mar 2008
    St. Louis, MO
    4,877
    The modeling involves some decently complex math unless you know exactly what DMRs are required.
    I have it worked out to convert actual airflow into accurate throttle relation tables, but I’ll keep that one to myself.
    Copying the throttle tables out of the ZR1 won’t do you much good. The throttle effective area vs percent relation along with effective area is a function of the overall air intake system and not just the throttle body. Copying the LT5 stuff into LT4 causes idle oscillations. Ask me how I know. ��
    Aug 2009
    Calibrating
    3,412
    Nice!! Look forward to playing with it!
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen5 Viper
    Ultima RS with C8 drivetrain
    May 2003
    South FL
    1,587
    Niceeeeee work, Dave! I actually never change throttle size as I pretty much found a bit of a "hack" in how I model airflow that seems to keep things happy. It will be interesting to play with the new tables.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
    Mar 2024
    Just in the knick of time. I'm working on a LT1 w/Whipple and KaTech 112mm TB. Was having a heck of a time with it. After playing with the main TP vs Airflow table, I was able to get it idling much better. I will report back later with more info.
    May 2006
    Waterbury CT.
    306
    Yes Greg explained that to me with Emphasis on Effective.
    I am not so much looking to copy them but use them as a reference as to direction of change.
    You are an Engineer, I'm a Reverse Engineer LOL.
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    537
    Teddy,
    Saw Nick on Thursday at a Trade show in Charlotte and we spoke about that request. He says he might get on it...Kinda a pain in the ass but he was intrigued by it...lol
    Engine Development/Powertrain Calibrations/Track Support/Consulting
    www.htrperformance.com
    [email protected]
    May 2006
    Waterbury CT.
    306
    Quote Originally Posted by Redline MS View Post
    Teddy,
    Thanks Howard.
    May 2003
    South FL
    1,587
    I tested these new tables on a client vehicle today with positive results. Hint, don't increase these tables by a ton and keep your changes smooth and uniform like you do with the MAF. Relatively small changes to the tables resulted in noticeable changes in the logs. They also had a direct effect on idle timing.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
    May 2006
    Waterbury CT.
    306
    As expected based on the logic as I understand it.
    Any chance to adjust the column header instead? Maybe would like the change to extend to other tables that we don?t see?
    May 2003
    South FL
    1,587
    I dunno, I tried similar changes on another car and the car started surging. This is going to be a tricky table to learn but I'm sure we will figure it out over time. So far it seems like the LT4 cars are more sensitive to the changes vs the LT1 cars. But my sample pool is still very small.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
    Mar 2008
    St. Louis, MO
    4,877
    To be blunt, it's not going to be a guess and check scenario. You need to familiarize yourself with sonic airflow if you want to do it right.
