Originally Posted by
Russ K
I set codes P0140 & P0160 to no error reported, this will eliminate those codes. Codes P0174 & P0175 had the check mark removed from the SES box, I checked them for you.
You had the trans force motor current table lowered a lot, I leave that table stock & just zero the 100 psi column. Then I firm the shifts using the shift pressure tables. A Corvette 2-4 servo would really firm up the wot 1-2 shift. But give this trans tune a try. I left all your shift points & TCC lock up speeds alone. I also reduced the upshift torque management tables by 50%.
Your PE tables were still delayed as stock, so I made the changes to eliminate any delay going into PE.
Russ Kemp
