just did some logging but I'm getting this error when I try to view it. I have version .18. Any ideas?
Was this an upload from a stand alone data logging session? (no laptop in car) And did you turn off the logging before turning off the car?
If not the log is probably junked.
Always Support Our Troops!
I get this message when I try to look at a log somebody posted
'99 Silverado ECSB w/5.3, Patriot Performance Heads (2.02in 1.57ex) milled .050, LSXrt intake w/FAST 102mm TB, Comp/EPS Cam (226/230* dur .598/.600" lift 113 +2 LSA), 44# injectors, LS7 Lifters, Stock Rockerarms, Double Roller Timing Chain, ARP Head & Rod Bolts, HV Oil Pump, Vigilante 9" Converter 3600 stall, FLT Level 5 4L65E, K&N 77 series, Pacesetter LT, No Cats, Magnaflow Mufflers, True Duals, TB Bypass, Truetrac, 4.10's, E-Fans, HP Tuner
'10 Camaro 2SS/RS RJT, L99, A6: Stock
its generally caused by either a bad upload from a member of the forum or a bad download on your end where you only get part of the file for some reason.
