Results 1 to 8 of 8
Thread: AFR goes back to where I started
    Jul 2006
    30
    I tried Russ's open loop maf tuning, and it seemed to be working fine(during).
    Cruising afr was 14.5-14.7. I was happy with it.
    Then I went to tune the wot values, and my cruise afr is back to 16.0 (where it was before I started)
    I'm stumped...
    What did I do wrong?
    2002 heads/cam V6 Camaro
    are you still in openloop? if so that would be why, until you go back to running closed loop, your afr will be off when no in closed loop or PE.
    Jul 2006
    30
    No... the afr is correct while I'm in open loop.=14.5-14.7
    Then I go back to closed loop, and it's off.=16.0
    This tune method has not worked out for me so far. I didn't replace the NB O2 with a WB. I have a bung for a WB. But I click the open loop button within the HPT Scanner.
    Quote Originally Posted by joe02
    when in closed loop what are you commanding for an AFR?
    Jul 2006
    30
    in closed loop it's stoich; 14.7.
    In open loop, I set the PE table to command 14.7, and it worked, then I changed all the settings and went back to closed loop, and that's when the afr went back to 16.0 (which is what I had before I started)
    u might try physically unplugging the stock nb's.
    this will force what your lookin for.
    Jul 2006
    30
    I do have an exhaust leak, but I don't think it was there on my initial attempt. I'll get that fixed and try again.
    Can you reset the fuel trims too much?
    Advanced Tuner johnh's Avatar
    Jul 2004
    Michigan
    238
    Only in the sense that you don't give the PCM enough time to learn....meaning it does take some driving for the trims to level off
    2017 Chevrolet SS, Orange Blast Metallic, Rotofab CAI. Headers coming soon. Stock Tune for now
    Previous Rides: 2008 G8 GT, 2004 GTO, 2004 GTP, 2002 TA
