Okay, what does load (g/cyl) do you usually read on a cammed 5.7 car? Usually anywhere from .76-.84 grams per cylinder. I'm having this problem where the loads are completely inaccurate for my timing/retard histograms. Everything is less g/cyl than usual. However while logging, it is obvious that the motor is taking timing from the correct cells or load.
I have an updated scanner log that I use, so I figured I had just screwed something up. Well after loading the default scanner, I am still having the same issues.
What have I screwed up?
Thanks,
Kyle
