I'm having a strange idle problem that I can't seem to figure out. Cold or hot start, it idles exactly where its supposed to. Coming to a stop or pushing the clutch in is fine also. What I'm having a problem with is driving the car and stop for gas, shut off the car. Fill up and restart the car, idles perfect. But the problem is moving away from the pump. As soon as I stop to pull out, it'll idle at 300-500rpm and slowly come back to where its supposed to be. I can do this same thing over and over and it'll do the same thing. After I drive, it'll idle perfectly again.
Why and what is causing this? Only after a drive and shut down/restart does it do this. It was doing this at the track also, especially after doing a burnout.
Any help would be greatly appreciated. I can post the hpt file if needed, on my laptop and not on this computer.
