Problem 1:
I just converted my standard OS to a 2 Bar the other day. I bought a 2Bar Map sensor from summit part# MSD-2312. I got it all installed loaded the 2bar os and everything was cool. but i noticed that the MAF was still giving PCM inputs cause my timing only jumps around when i use the map and not is SD mode. I thought the MAF is disabled with a 2bar os?? well i set the MAF fail to "0" and the truck runs great. my question is do you have to set the MAF fail to "0" when running a 2bar?
Problem 2:
I followed the demo that shows how to convert to 2bar with the VE, but my 2bar VE table starts at 30(kpa) not 15(kpa) like the standard OS and goes by 10's up to 210(kpa). Is that right? on the demo is shows the 2bar still starts at 15(kpa) and goes by 5's up to 210(kpa).
Attached are 2 tunes with their scans. The "2Bar New VE" is the way the VE table should be set up according to the demo, but with this tune at 5lbs of boost the truck shuts down and the reduced power light comes on With codes [PCM] P0068 MAP/MAF-THROTTLE POSITION CORRELATION, [PCM]P0103 MAF SENSOR CIRCUT HIGH FREQ.
The "2Bar Old VE" is with the exact VE table of my standard OS tune
Also my histo for VE wont read stft past 50kpa.!
i'm open for suggestions!!
