I have been tuning a modified L-32. AFR is pretty close to commanded, KR is 0.2* at max. and I've begun playing with ignition timing. The timing at high loads does not seem to be following what my spark tables command. The low octane spark table is 4* lower than the attached hi octane spark table. The ECT and IAT spark tables (which are also attached) do not seem to be causing this. Please refer to the section around frames 2700 to 2710 in the attached HPL file for an example. IAT was 73* F at frame 2707.
Specifically, spark is at 14.5* in frame 2707 and I think it should be 10*. I know 10* is not enough but am reluctant to advance spark until I can get it to do exactly what I want.
What am I missing?
Mods are available but don't seem relevant to this question.
