My FJO wideband manual has an output calibration chart. At 14.5 AFR there should be 2.45 volts between the 2 wires going to the EIO. At 13.0 AFR, there should be 1.97 volts. Not sure what the voltage is on the PLX, but once you find out, then hook up a volt meter to the 2 wires at your EIO and compare the voltage to the AFR in the scanner. Do this with the engine running.
Russ Kemp
