Results 1 to 3 of 3
Thread: newbie questions on a 02 head and cam
    Nov 2004
    Fist i would like to say their is a great deal info on this site. I have only had the software for about a week and just been playing around with stuff trying to get the idle right.
    : i am running 42# injectors with a tsp 231/237 and a set of ls6 heads stage 2 with 2.06 1.7 valves and a 200 shot of juice. first off i know that the enjectors are two big right now. But with a stroker motor in the works they should be alright. i think!
    Question 1: how much should i have to scale the ifr table to get them close to being right? Or should i say to start getting the ltrims negitive, i have already used the injector spreed sheetto get base # when i get home from work i will post up some more info if you guys need.
    Question 2: After i get the injectors right what would be the next step?
    please be patiant with me guys i am not very computer inclined. i can turn wrenches and dial in a carb but this is all new to me. Any help would be greatly appreciated, and please help me out with the menues to and the lingo
    sorry for the long post but i am sorta confused.
    thanks in advance.
    jason
    Nov 2002
    Central Florida
    2,503
    Re: newbie questions on a 02 head and cam
    I would scale the IFR, flow rating for flow rating,
    as the first step and then zero the trims, let it
    have its learning time and then take stock of the
    situation. Changing too many things at once
    can muss up your mind. The injectors are only
    too big, if you are falling below the minimum
    actuation pulse width for accurate fuel shot at
    idle. On an A4 you may well have enough parasitic
    engine load that this isn't an issue.
    You need to check the ratings basis for the stock
    and new injectors, make sure they are on the same
    (4-bar, 5-bar) pressure differential basis. When you
    have same-basis numbers then scale the IFR table
    by (new/old). Like 42/28.8=1.4583, multiply by. But
    check the numbers and bases carefully, don't take
    my values at their word.
    Nov 2004
    ok sounds good i will give that a try, about how long is the learning time? I will let you know how it turns out.
