Guys when I do my scanning.....The section for the misfire will be (incomplete) Any idea why
Holden V8 A4, Comp Cam, Headrs, ASP pullys, K&N filter, HPTuner.&&
Have you deleted the DTCs for the misfire?
Many people with a large cam do, because the cam will cause false misfires.
I would check that, 300 is the one that was turned off on mine.
01 Trans Am WS6, &&M6 ASC# 3201 420.5 HP 394.2 TQ&&TSP 228R, PRC 5.3 RHs, QTP\'s with catted Y, Asp, HS Rockers, Jantzer TB, !Baffles+sealed airbox,Factory Hurst w/LSS, Magnaflowatback, Direct-flo lid
killer01ws6,
where can I find the (300) that you are talking about. is it the 300-Engine Misfire Detected? if it is the one? mine is set to ErrorMode>3-no Error Reported.
And the SES Enabled >Off
does this help
Yes that is the one he's talking about. Has somebody tuned your car before or did it come that way from the factory?
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
11.301 @ 129 1.68 60' MT DRs
11.85 @ 124 1.90 60' street tires
Ok so what I have to is only set it to ON and keep it to option #3
No my car from the factory that way.
Guys Please I'm waiting for anyone to help...... :'(
Well,Ok so what I have to is only set it to ON and keep it to option #3
The way my car is stock is:
SES Enable ON
Error Mode One - MIL in second error
I used to have a P0300 come on with my car every once in a while so I edited:
Edit->Engine Diagnostics->Misfire->Max time between events->low rpm and changed all values to 32000.
Try that and see what happens.
Mike
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
I will try right now...
mine is set on >32767 ....except one wich is 1750 @1200RPM and 18.75.
If that doesn't work then you most likely have a pretty stout cam so then try your idea of:
Enable ON
Error Mode Three - No DTC reported
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
Thanks bro I will do it right now.
And you are right....problem solve
