Guys after reading two other friends VCM this is what I got.....
1-
At the engine mod:- Idel:
Cooling Fan Airflow
Fan 1 (.90)
Fan 1&2 (1.20)
My freind got for fan1 (0.15) and for Fan1&2(0.37
which one is correct
Also
Throttle Cracker
Enable speed (3)MPH
Disable speed(1)MPH
My Freind
Enable speed (1)MPH
Disable speed(2)MPH
2-
At the engine mode:-Torque Mgmt:
Enter Abuse Mode Test if:
RPM>12800 Speed<0
My freind
RPM>6600 Speed<0
Which one is Correct
3-
At the Transmission Mod:- A4 Shift Speed
Wot Shift Enable %TPS (99)
Wot Shift Disable %TPS(96)
My Freind
Wot Shift Enable %TPS (90)
Wot Shift Disable %TPS(86)
Which one is Corect
4-
At the Engine DiagnosticsMod:-
Misfire Detection Max Temp (266)f
Misfire Detection Min Temp (-40 )f
My freind:
Misfire Detection Min Temp (19 )f
Thanks Guys for you time and effort to help others....
