Two questions...
1. I have been looking at part numbers for LS1 PCMs. Let's discuss Camaro's for example. The 1998 is its own breed, the 1999-2000 are the same AC Delco PN, and the 2001-2002 are another PN. If I had a 2002 engine and harness with the red and blue plugs, but for some reason, did not have the PCM that came with it, and I found a 2001 PCM for an LS1 Camaro with the same rear axle and transmission, would they work together without programming being required? How about if the new PCM was for a similar 2000 LS1 Camaro (different PCM PN)? I have looked at the Pins for the PCMs, and they look to be going to the same things. I know a 1998 would not work.
2. If I ordered a new PCM from GM (assume a GM crate LS1 engine is used) and had them program it with the right year, tranmission, axle, etc. program, I know that would obviously work. What VIN would be registered on the PCM? Doesn't HPTuners need a VIN for credits and such and to know what options are available for your PCM? If so, what happens and how does this all work?
Thanks.
