Please list step by step what you did to get the error. I am unable to recreate it with .18.
If I cannot recreate it i cannot fix it.
Bill
Bill
Also, when I click "start"in the bottom left corner, and my mail programs come up (Internet; E-Mail; an the latest programs I've been using, for VCM Scanner, there's the usual "Lightning bolt" symbol; but for "VCM Editor", there's a square, and a little "2" next to it. Don't know if this means anything, but I'm just trying to help in any way
Now, all my messages are backwards!!! I'm haunted!
Anybody know anything about this? I'm trying to do a basic sd tune my truck by doing the "copy/paste Special" My LT's into my ve table, I get this message.
see the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidCastException: QueryInterface for interface IOleDataObject failed.
at System.Windows.Forms.UnsafeNativeMethods.OleGetCli pboard(IOleDataObject& data)
at System.Windows.Forms.Clipboard.GetDataObject()
at j.(Object A_0, EventArgs A_1)
at System.Windows.Forms.ContextMenu.OnPopup(EventArgs e)
at System.Windows.Forms.ContextMenu.Show(Control control, Point pos)
at System.Windows.Forms.Control.WmContextMenu(Message & m)
at System.Windows.Forms.Control.WndProc(Message& m)
at C1.Win.C1FlexGrid.Util.BaseControls.ScrollableCont rol.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
Assembly Version: 2.1.18.0
Win32 Version: 2.1.18.0
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/VCM%20Editor.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
C1.Win.C1FlexGrid
Assembly Version: 2.5.20053.220
Win32 Version: 2.5.20053.224
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/C1.Win.C1FlexGrid.DLL
C1.Common
Assembly Version: 1.0.20031.116
Win32 Version: 1.0.20042.118
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/C1.Common.DLL
C1.Win.C1Chart3D
Assembly Version: 1.0.20053.15236
Win32 Version: 1.0.20053.15236
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/C1.Win.C1Chart3D.DLL
C1.Win.C1Chart
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/C1.Win.C1Chart.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
What version are you using? Please provide the scan log & editor file and a step by step so we can reproduce & fix.
Bill
Ver 2.1.18.0
I'll try to get more info
Attachment 6402
Attachment 6403
Here's the log, and the current tune
Hope this helps
I highlited the LT histogram, hit "copy", then highlited my VE table and did "Paste Special" to copy it into, then I get the message.
Please list step by step what you did to get the error. I am unable to recreate it with .18 with the little info you've given.
Bill
I just completely unloaded, and reloaded HP Tuners. I'll report back in a few days after I redo my logs.
I got that same thing, I just shut down my computer and restarted and it worked fine. Dont remember exactly what I did but know it was my fault. (was something stupid like complete rewrite with the car running or off the wall crap by accident that you dont want to do.)
After a reboot all was well and have not seen that since.
99Z A4 w/ SS LT's, h/f cats, magnaflow catback, port/polish t/b, egr deleted, ls6 intake, lid, 3.73's, hpt, performabuilt level 1 tranny, 3600 stall, Stage 2.5 (5.3 heads), Torquer 2 cam, 42# reworked injectors, TR6 plugs.
2007 Avalanche LTZ - Catback and Eibach springs
