I am kind of confused here. I got the VE fairly decent. went back to closed loop and tried to calibrate the MAF. Most of the numbers in the MAF-AFR Error is 0 or 1, well from 6750 hz and below. Above that Hz I am getting anywhere from -7 to a -14.
I cant get these unless I go WOT. I thought I read somewhere that when dialing this in you should be nice and easy on the gas. How will I get these then?
