Not moving fuel cutoff
What sensor is referenced for the not moving fuel cutoff. I tested this out and it is non functional. The vehicle is not an ABS vehicle, so I am wondering if ABS sensors are monitored for this function or is the vss in the tranny referenced.
Thanks!
Don
HP Tuners Owner
some vehicles it is not used, others it is used for reverse gear rpm limit.
What's the trigger for it to use the table? Can I make it functional? I would like to use it as a launch control on a manual car. Is the table active and just needs inputs from a reverse switch indication or similar? Was this used on automatic cars?
HP Tuners Owner
sorry, i got confused with the speed limiter
The Not Moving limiter works in PN for Auto trans or below a calibrated speed for manuals (the cal i am looking at is set at 20mph).
hmmm..so it should have been working for me. Where is this speed set at? Is that in my definition file (I am using the 2.2.19 beta)?
Thanks!
HP Tuners Owner
email your file to support along with a link to this thread.
Chris...
Any luck with this? Thanks!
