Results 1 to 2 of 2
Thread: LTFT @ Wot?
    Apr 2006
    17
    LTFT @ Wot?
    I'm tuning on a procharged application with 8psi of boost. I have the commanded PE set to 12.0. On the dyno it is adding fuel via LTFT @ WOT after a couple of pulls. The actual A/F ratio is deep in the 11's.
    Also we're going to 12psi with this car should we forget trying to play tricks with the tables for this and go to a 2 bar sensor and tune?
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Thats why you have to tune the WHOLE range from idle to WOT and not just WOT. If the fuel trims see a lean mixture before WOT, it remembers and locks into those values of that FTC at WOT.
    Sulski Performance Tuning
