Thread: Idle issue, rev limiter
    Aug 2007
    23
    I am very new to tuning my car. I got HP Tuners in the mail today. I drive a 2000 Camaro SS with an LS1, all info is in the sig. Currently my ac-on idle is fine, but when the ac is off the idle isn't very good. It will bounce from 450 to 600 and not sit there. It does it a lot more when the car is in gear than when it is in neutral or park. I looked into what I think was the IAC and it was set to as low as 500(rpm) if the temp was hot. Is this correct? Also, when I get on it, I hit about 6200rpm when I should only be getting to 6000 or less. I found where there is a fuel cutoff in neutral and park at certain rpm's but couldn't find for when i am driving. Also I know I need to change my shift points but havn't had the time to do that and run the car to see how that controls the shifts. Thanks!
    00 SS A4: Pacestter LT, Ory, Borla, 3.73, Fuddle 3200 stall
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Read the stickies, they are there for a reason. Post tunes and scans if you want help. Otherwise, we can't do much for you...
    Sulski Performance Tuning
    Aug 2007
    23
    fixed the idle issue, i haven't had a chance to get a log file yet but now all i am working on is the shift points
    Jan 2005
    Concord, NC
    8,093
    ok, well anytime you have an issue post up your most current scan with proper parameters and the tune. This way we can review it to look for the issue.
